Rear axle of Volga 24
Johnny Moped
17 Дек 2014
:hi: Hi to everyone, I'm Michal from Poland and I have questions about repairing rear axle in my GAZ24:
-What is the gear ratio for the pinion gears? I found pinions with ratio 41/10 but I'm afraid theyre to GAZ 21.
-Why in my parts catalog I have a whole bunch of rings with different thicknesses to distance the pinion gear? This is the usable range of thickness?
cheers to all :drinks:
Dart Sergius
5 Июн 2012
965
252
Марат Малов
15 Дек 2007
828
344
Johnny Moped, Okay, Johnny. If your car is GAZ-2401 (NOT GAZ-2410), your gear ratio is 41/10. For all newer GAZ is 3,9 gear ratio.
Thikness of ring is varies from gear to gear, Soviet Car, yep. You can select thickness like in manual - setting up pinion gear or "настройка зацепления шестерен заднего моста".
Johnny Moped
17 Дек 2014
интересно, а как топикстартер попал в нужный раздел, если по русски не гооворит :)
It wasn't so hard to choose proper section
I think that I need:
1x this: http://avtoclassika.com/car/gaz-24/739/10981/
1x this: http://avtoclassika.com/car/gaz-24/739/28893/
and 2x this: http://avtoclassika.com/car/gaz-24/738/10978/
do I need anything else?
EDIT
http://www.avtoall.ru/catalog/gaz-4/legkovye_avtomobili-18/gaz_24_10-15/most_zadniiy-75/
Yo, Nigga :)
Okay, man doya need the part number 13 to ya louraider or numba 22? So man, mai english is very well :hi::hi:
I need all sealings, already I have all bearings, and I'll buy at bargain pinion gears and differential case
Марат Малов
15 Дек 2007
828
344
Numba 13 - 42х75х10х15.5
Numba 22 - 52x72x10
No more sealings of that dimensions in Volga, Bro!
Добавлено через 9 минут 58 секунд
No, nigga. Zis sealings for da GAZ-21. There is two sealings on GAZ-21. On GAZ-24 only numba 13 in my schema or diz sealing:
So, my black Volga Bro, Have a nice repeair!
Burik
12 Сен 2011
3,233
988
465
15,242
8,672
Даже не знаю что делать с темой. С одной стороны язык форума русский:
II. Правила написания сообщений.
1. Официальный язык общения на форуме - русский. Просьба к иностранным гражданам - использовать для перевода текстов сообщений специальные серверы перекодировки транслита:
www.translit.ru или http://winrus.com/klava.htm
Но во всю идет общение, только наверное многие не могут присоединится к "разговору".
Dart Sergius
5 Июн 2012
965
252
неверно составлены правила. Представь что будет если он напишет по английски, потом транслирует с помощью того же www.translit.ru в русский ?
Ужасно :drinks:
sstek
1 Июл 2012
Hi! Beware non original bridge!
Original size seals:
Corteco (rear axle shaft) 12010977 52x72x10
Corteco (main drive seal) 01026326B 42x75x10
Compartible seals:
Ford Tranzit 01026326B (and analogues) 42x75x11,5(I use it)
Mercedes Atego 011 977 74 47(46? not tested yet...) (and analogues) 52x72x12
